Hi all,
I have the f2-210, it works fine for months, and after I turn it off to move it to a new shelf, it stops working.
I tried to reinstal TOS but got this problem.
TNAS PC still sees my NAS's IP, but every time I clicked "Log In", it showed "404 Not Found nginx/1.16.1" regardless of Browers and how many times I tried to reboot router...
I tried to Log in using Putty SSH but got "Network error: connection refused." And I can't access TNAS via anything.
Please help,
PS: I don't have anything else that is able to format my hdds.
404 Not Found
Re: 404 Not Found
Did the situation you encountered occur when the hard disk was installed or not?
Please try clearing your browser cache.
Regarding reinstalling TOS, please refer to:viewtopic.php?f=76&t=423
Re: 404 Not Found
It occurred with both situations, with and without the HDD.
Since I tried to reinstall as your instruction on the forum, it never passed that error no matter what I did.
So I called the company where I bought this item, the support guy worked his magic for almost 4 hours to make it work again, I didn't know exactly how he did it but something like unmount the HDD and then remount it via SSH on PUTTY.
