Backblaze B2 - Operation Failed on configuring connection
waymda
Australia
Post by waymda »
Multiple attempts and the operation fails
Have tried:
uninstalling/resinstalling CloudSync
different brower to ensure clean cache and cookies
creating a Gdrive connection - this worked
beakerbite
Re: Backblaze B2 - Operation Failed on configuring connection
Post by beakerbite »
I haven't been able to get either B2 Sync nor S3 Sync working. At least with S3 it is able to load up the buckets, so the key is working, but trying to progress past that just gives me "Operation Failed" with no indication as to what's going on. I'm using TOS 4.2.41 on an F4-210
Regarding this issue, please try to login in SSH,input the following instuction:
ter_curl --insecure -o /etc/ssl/certs/ca-certificates.crt https://raw.githubusercontent.com/bagder/ca-bundle/master/ca-bundle.crt
beakerbite
I had to run it with sudo to get it to work.
Return to “CloudSync”
