Docker Manager 1.2.6 Update Released
Discussion about Docker
ColaChen
Post by ColaChen »
Dear TerraMaster users,
Thank you for your continuous support and attention to TerraMaster products. The Docker Manager application is now available in a new version! In order to meet the diverse needs of our users and address the feedback and issues you've shared, we have made fixes and optimizations in the new version. We sincerely hope you will have a better experience in your future usage.
Docker Manager 1.2.6 introduces several new features and fixes some defects to provide you with a more enriching user experience. Here are the detailed updates:
1. Added the function to create mounted folders.
2. Added the function to create custom networks.
3. Fixed some issues in the container editing feature.
4. Fixed some issues in the container configuration copy feature.
5. Fixed some issues in the container import/export feature.
6. Fixed the issue where the gitlab-ce image couldn't run properly.
You can download the latest Docker Manager 1.2.6 version through the following methods:
1. Visit this link for downloading: https://dl.terra-master.com/cn/APP5.1_X ... x86_64.tpk
2. Update the Docker Manager application through the TOS Application Center.
Important notes:
This version of the application has significant changes. We recommend backing up your existing container or image data, uninstalling the Docker Manager application, and deleting the DockerData shared folder before installing the new version of Docker Manager.
If you encounter any issues during usage, please provide feedback in the corresponding section in TerraMaster official forum, or describe the problems you've encountered and send screenshots to [email protected].
Sincerely,
TerraMaster Product Team
tommi2day
Germany
Re: docker updata
Post by tommi2day »
- and, don't forget, it fixes the nasty dns resolution problem if the container is running as non-root user :D
main: T9-450
tab3rware
Spain
Re: Docker Manager 1.2.6 Update Released
Post by tab3rware »
Yeah... big problem found...
/VolumeX/DockerData has moved to /VolumeX/@DockerData, this movement BROKE ALL CREATED VOLUMENS...
Great...
tab3rware
Spain
Post by tab3rware »
tab3rware wrote: 16 Sep 2023, 01:27 Yeah... big problem found...
Great...
First, the terramaster staff warned us that there were important changes... I didn't read it, my mistake. Thanks Terramaster.
To fix the problem of broken volumes, just delete the containers and re-release them. From portainer, you can "recreate", but as we have been warned: BACKUP EVERYTHING!!!!
Return to “Docker”
