The virtual machine 'hjik' has terminated unexpectedly during startup with exit code 1 (0x1)
when I click in details I have this:
Exception Object
[message:protected] => The virtual machine 'hjik' has terminated unexpectedly during startup with exit code 1 (0x1)
[string:Exception:private] =>
[code:protected] => 0
[file:protected] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
[line:protected] => 2443
[trace:Exception:private] => Array
[0] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/lib/vboxconnector.php
[line] => 951
[function] => remote_progressGet
[class] => vboxconnector
[type] => ->
[args] => Array
[0] => Array
[progress] => a77d5cc369460113-0000000000000004
[1] => Array
[file] => /Volume1/@apps/virtualbox/webui/endpoints/api.php
[line] => 316
[function] => __call
[type] => ->
[args] => Array
[0] => progressGet
[1] => Array
[0] => Array
[1] => Array
[0] => Array
[data] => Array
[responseData] => Array
[info] => Array
[completed] => 1
[canceled] =>
[description] => Starting VM
[operationDescription] => Creating process for virtual machine "hjik" (headless)
[timeRemaining] => Array
[timeElapsed] => Array
[days] => 19611
[minutes] => 25
[seconds] => 57
[percent] => 0
[success] => 1
[key] => 53474945cfd7ac0bf8114767c209c2a6
[errors] => Array
[persist] => Array
[messages] => Array
[previous:Exception:private] =>
i uninstall virtual box, reboot, install again, reboot and created new virtual machine.. I tested load images of windows on folder public too... multiple tests and no success... this error persists
anyone with this problem? how to solve?
