I have a back up of my computer completed.
How do I initiate a restore of this back up?
Step by step directions would help. Especially starting with create and defining the Restore of source location and Destination.
Thanks,
Centralized Backups How to Restore
Re: Centralized Backups How to Restore
{L_BUTTON_AT}Scottnorwo
What type of data do you need to restore? Is it data restore or system restore? You can refer to this link:https://help.terra-master.com/TOS5/view ... d%20BackupTo contact our team, please send email to following addresses, remember to replace (at) with @
I made a backup of my PC and now I don't understand how to restore from this backup.
Where can I download the ISO image? Where are the recovery instructions?
All I have is a backup on my TNAS-223 and nothing else.
I also don't understand how to restore the system after a failure.
There is no information on the Internet where to download a bootable flash drive for recovery.
If you restore to an already installed Windows, it is impossible, it will not be able to overwrite many files and re-divide the partitions on the disk, since Windows is already running. You need a bootable flash drive, but it's not there.
It seems to me, but this backup method will not be able to restore the computer to its original state.
{L_BUTTON_AT}баб28
Hello, you can download this tool to create iso files in Windows.To contact our team, please send email to following addresses, remember to replace (at) with @
{L_BUTTON_AT}баб28
I wanted to make a bootable ISO image, but I couldn't do it. Error 0x80040211 comes out and nothing works
During automatic recovery, it is constantly rebooted.
If you choose manual recovery, it does not see the disk to which to restore
Doesn't work in general (((
{L_BUTTON_AT}baf28
This is a partition from which the original disk cannot be read. What tool did you use to burn the USB boot disk?
