Plex ERR_CONNECTION_REFUSED
Andreas83
Post by Andreas83 »
Hi there,
need your help please:
After installing the new TOS-version, I can't access anymore to Plex. I have re-installed the app , and now with the newest version. After clicking on the plex app, the system shows me an ERR_CONNECTION_REFUSED. I can't link Plex with my F2-221. I have an admin user, all folders are shared with all. I am lost, I can connect Plex anymore.
Could someone please help me out?
Thanks a lot
Terramaster: f2-221
TOS version 5.1.67-00214
Plex media version: 1.32.6.7371
Andreas83
Re: Plex ERR_CONNECTION_REFUSED
Post by Andreas83 »
Please, can anybody help!! Thanks in advanced
Noticed that you are using a model that is commonly used for TOS4.
If your storage structure is from TOS4, then the problem you may encounter is related to this:
viewtopic.php?f=28&t=4912
Taillandier
Virgin Islands (USA)
Post by Taillandier »
Solution to my problem
Download PLEX from https://www.plex.tv/media-server-downloads/ depending on your platform. Then go to application center/settings/manually installed the application
And HOP miracle, PLEX appears!!!!
A small downside, everything works except when you want to delete a file, an error message appears "A problem occurred while deleting this element"
Return to “Plex Media Server”
