About: https://github.com/johnmave126/extract-samsung-firmware
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
App download: https://tmnascommunity.eu/download/Extr ... ngFirmware
TOS4: http(s)://yournasip:port/modules/ExtractSamsungFirmware/www
TOS5: click on Support & Help from app description inside the App Center
A command line utility to extract Samsung SSD firmware updator from official iso images. Samsung is infamous for the awful Linux boot environment used by their firmware updators. This utility automates the procedure.
Usage
Extract Samsung SSD firmware from the iso file
Usage: extract-samsung-firmware.exe [OPTIONS] --file <FILE>
Options:
-f, --file <FILE> Firmware iso file location
-o, --output-dir <DIR> Target directory to extract to [default: .]
-h, --help Print help (see more with '--help')
-V, --version Print versionCode: Select all
# Samsung Electronics #
# Samsung SSD Firmware Update Utility Ver. 3.1 #
# Samsung Electronics Co., Ltd. (c) 2022 #
SCANNING -> -> -> -> -> -> -> -> -> ->
______________________________DISK(s) DETECTED______________________________
|#| Drive Model | Serial Number | Firmware |
|1| Samsung SSD 980 500GB | S64DXXXXXXXXXXX | 3B4QFXO7 |
|_|_________________________________________|_____________________|__________|
Press any key to continue...On Linux, an additional option -e is added to allow running the firmware updator directly (although not recommended).
