how i can fix them?
thanks
yes, one my friend told me there was an error ( raw read error rate to 1) and report uncorrect to 1 , not sure if is for thattommi2day wrote: ↑03 Sep 2023, 17:31 I am running a Raid5 with 4xMX500 2TB without any problems and warnings (so far). Do you have some smart errors on one of your drives?
The provided compatibility list looks a little bit outdated, can not believe the Samsung SSD list ends with the very old 8xx models and no pro model listed. The same for crucial. Why it should not be used? Its not marked as "Not recommanded" as we see in the hdd list. Means more "never tested" ?
Thomas
