Creating a user or folder with the same name
iou40p
Post by iou40p »
Hi All,
Am trying to create a couple of shared folders for the users, the system doesn't let me do this as the name is in use. If i remove the user i can create a folder with that name, or if i remove the folder i can create a user with that name. Is their a way round this? I have read on this forum that i have to turn off the User home folder in the user settings and i have done this and i still can't create a folder with the same name as a user, can anyone help.
iou40p
F5-422
iou40p
Re: Creating a user or folder with the same name
Post by iou40p »
Forgot to add, am using a F5-422 running the latest version of tOS
iou40p
F5-422
You are not able to do it. The user name is reserved for the user's home directory.
iou40p
Post by iou40p »
Is it possible to store files in the users home directory or is it for configuration files only?
iou40p
F5-422
User home folder is for user's private data, you can store your personal data in it. there is no configuration stored in this folder.
Return to “Privileges”
