TOS 5.1.67 (X86) is Released for Update
WARNING!
Since the new version of TOS 5.1 system requires more storage space, if your initial system was TOS 4.x and the system partition is 2GB, please do not update to this version.
To check your system partition size,
Go to "TOS > Control panel > System Info > Overview", and check the space from the item of "/" .
If your TNAS does not meet the conditions but your want to use TOS 5.1.67, you can refer to the following guideline: viewtopic.php?f=28&t=4912
Release Notes
Applicable models: F2-220, F2-420, F4-220, F4-420, F5-420, F2-221, F2-421, F2-422, F4-221, F4-421, F4-422, F4-223,F5-221, F5-225, F5-421, F5-422, F8-421, F8-422, F2-223, F4-223, F2-423, F4-423, T6-423, T9-423, T12-423,T9-450;
This update includes the following bug fixes and optimization for the previous version:
Bugs fixed
1. Fixed the issue where enabling TNAS power scheduling would slow down SMB speeds;
2. Fixed some issues in File Manager;
3. Fixed some issues related to Domain;
4. Fixed some issues in Volume and Storage Pool;
5. Fixed some issues with external devices;
6. Fixed some issues in Shared Folder;
7. Fixed some issues in Virtual Disk;
8. Optimized the synchronization strategy for the database;
What is new
1. Added thermal notifications for NVMe SSDs.
Important Notes
  • There is an error in the encryption mechanism of encrypted folders created on TOS 5.1.37, which prevents them from being decrypted in later versions. Therefore, if you are using TOS 5.1.37, before updating TOS, please back up the data in the encrypted shared folder, and then delete the encrypted folder. (Only need to deal with the encrypted shared folder created in TOS 5.1.37, other encrypted Shared folders are not affected by this)
  • The kernel of TOS 5.1 has been updated to 5.15. Since the Linux kernel has removed the Intel Celeron J1800/J1900 GPU drivers from 5.15, the models of this platform no longer support GPU hardware video acceleration. If you are a user of this series of models and need to use GPU hardware video acceleration, do not update TOS 5.1! Models involved: F2-220/F2-420/F4-220/F4-420/F5-420
  • Under normal circumstances, the system update will not affect the data in your hard drives, but for your data safety, it is strongly recommended that you back up your data before the update!
How to update your TOS?
Manual update:
1. Download the update package: TOS 5.1.67 (md5:fa5c0b7687ce785e607738ffe97cde92)
2. Go to TOS > Control Panel > General Settings > system;
3. Under the "Manual update", upload the update package;
4. Click "Apply";
5. After the system update is complete, you need to refresh your web browser;
6. Your TNAS's IP address may change after the system update, if you are not able to connect to your TNAS with the previous IP, you need to search the new IP again with the TNAC PC client;
TNAS PC:
After updating to TOS 5.1, you need to update your current TNAS PC to 5.0.33 or a later version, or you may not able to search your TNAS device.
1. TNAS PC 5.0.35 for Windows OS
2. TNAS PC 5.0.41 for macOS
It is recommended that you uninstall the previous version before installing this version of TNAS PC.
Issue report
If you encounter issues during use, please report to the corresponding TerraMaster official forum, or email your issue description and screenshots to pm(at)terra-master.com
joka388
Austria
Re: TOS 5.1.67 (X86) is Released for Update
Post by joka388 »
Still the same low SMB rate when changing on-times
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
gaz2k1uk
Post by gaz2k1uk »
No testing yet, but updated OK on my F2-422..
Setup:
System: F2-422
OS: TOS 6.0.535
HD: x2 IronWolf 6TB (RAID 0)
Notes: 8GB System Partition!
Backup:
USB COPY: Seagate 8GB External Expansion HDD
TMpzhen
Post by TMpzhen »
{L_BUTTON_AT}joka388
Can you log in to ssh and send us the output from two commands :
cat /proc/cmdline
and
uname -a
Have you set the boot order on the BIOS? You can try to set the hard drive to boot priority or unplug the USB on the TNAS and then boot the TNAS.
UncleJohnsBand
Post by UncleJohnsBand »
Updated my F5-221 with no issue. Seems to be running fine.
[at=joka388 post_id=29234 time=1692945279 user_id=4838][/at]
Not encouraging. I think I'll wait before I update (and maybe a clean install). :cry:
joka388
Austria
Post by joka388 »
TMpzhen wrote: ↑25 Aug 2023, 17:53 Can you log in to ssh and send us the output from two commands :
cat /proc/cmdline
BOOT_IMAGE=/boot/bzImage type=raid
uname -a
Linux TNAS-6833 5.15.59 #229 SMP Tue Aug 8 13:50:13 CST 2023 x86_64 GNU/Linux
joka388
Austria
Post by joka388 »
Gremlin wrote: ↑25 Aug 2023, 19:09 [at=joka388 post_id=29234 time=1692945279 user_id=4838][/at]
I did a clean install with version 5.1.41 and made no changes to the start times. Then I installed version 5.1.67 and changed the start and stop times. The SMB transfer rate dropped again.
For 221 series, the hpet option is set as enabled by default in BIOS, As a result, a large number of invalid requests are generated, which occupy system resources, and the speed of SMB is affected. We have stopped requesting hpet in the latest TOS version, and we have verified that the countermeasure is effective. As for your case, we need further verification.
You can try to change the hpet option to disable in BIOS.
