sorry for my English out of Google Translate. I have an incorrect user problem on the PC impossible to connect except with ssh the no problem an idea?
problem user and password
Re: problem user and password
What version of TOS are you using?
It seems that there is a problem with the system files of TOS. You can try to reinstall TOS to solve it:
viewtopic.php?f=76&t=423
If you are using TOS5.1.40 and above, the problem may be caused by insufficient system partition, please refer to this to solve it:
viewtopic.php?f=28&t=4912
I have a similar issue, after the TM has been operating for a couple/few days and I attempt to access it, it says the user name and password are incorrect, If I unplug and replug the device its ok for a few days then the issue happens exactly the same way again.. over and over.. only started doing this after the 5.1.41 update
Hi sischka,
do you still face this problem? I just had it myself 3 Days after fresh Installation (latest V5).
F5-221 | 5.1.67-00214
- trasmussen
I also have this problem, now i have learned from the firtst time it happened to alsways create a second admin user or more..
Running v. 5.1.67-00214 on a F4-423
When i use the "secondary" admin this never happens, but if i go with this acccount and reset the password on the "normal" admin i can login once or twice then it stop working again.
Has this ever been solved other than a reinstall?
Thomas
Thomas
We have not yet verified the situation you described, but we will pay attention to the relevant situation.
This is a higher version of TOS5 that you can update, if you need it:
viewtopic.php?t=6124
