Docker on the F2-210
Discussion about Docker
scrappysphinx
Post by scrappysphinx »
Hi all, bought an F2-210 NAS second hand quite cheaply without disks. It arrived yesterday and i have fit 2 2tb WD Red drives in there, installed TOS 4.2.43 and its been up for the past 24 hours or so. I wanted this NAS for PS3Netsrv so i am trying to get docker working to install the container however whenever i install docker it goes to a configuring status followed quickly by stopped. I read some posts on these forums about maybe a kernel problem and to run the TOS update package so have ran the 4.2.43 update package but i still cannot get docker to actually start.
My next step was to do a factory reset and try again but still no joy.
Anyone have any ideas how to get docker to actually work?
Thanks and regards
crisisacting
Re: Docker on the F2-210
Post by crisisacting »
It may require a kernel reset via viewtopic.php?f=76&t=696
Had a 210 that couldn't get Docker to load & kernel reset fixed the issue at that time.
scrappysphinx
Sorry for the late reply i got hold of a synology nas so put the terramaster to one side.
So i have followed the process you linked to reinstall the kernel but i am still unable to get docker to work.
It just keeps stopping, if i manually try to start it says configuring then stopped followed by operation successful but its still stopped and does nothing.
Any other tips appreciated
According to existing similar cases, this situation may generally be due to the fact that the Docker related files have not been installed yet. You can wait for a while and try again. There may also be read and write problems that cause the Docker file installation to fail or be missing.
It is recommended that you check for possible file system issues by referring to this:
viewtopic.php?f=79&t=2575
You can also check your hard drive for any bad sectors.
Return to “Docker”
