I have a new TM T6-423, which works great. It's running 5.1.41-00005. When I boot my laptop (Thinkpad X13) in Windows 11 and go to browse the network in File Explorer, the NAS shows up and I can select/view/mount shared folders, using SMB/CIFS. However, when I boot the exact same laptop into Linux Mint 21.2, the File Browser cannot see the T6-423, although it can see my Synology NAS. I can access the T6-423 just fine using its IP address (which I have fixed with an address reservation on my router), and everything works great using SMB/CIFS. However, I'd really like to be able to do it by name or by browsing, instead of having to remember and type in the IP address. How do I do that? I can't find this issue on the Terramaster forum or the Linux Mint forum, but it seems like there should be an easy solution
FYI, in the Control Panel / Network Services / Discovery, UPnP is disabled, Windows Discovery (wdss2) is enabled, and Bonjour is disabled. Screenshots are attached.
Thanks for your help!
Cannot see NAS (T6-423) from Linux client
Re: Cannot see NAS (T6-423) from Linux client
You can try turning on UPnP, Windows Discovery (wdss2) mainly for new versions of Windows 10 and Windows 11.
