Fresh Start!
Tricky
Fresh Start!
Post by Tricky »
I have 2x F5-221 and have been using one with Truenas but in the interests of conformity and wanting to try the TRAID configuration, and also needing to back up a lot of data on the other machine, so if I put back the original boot USB drive and initialise as per usual what version of the software will I get from the online initialisation and will this then provide enough storage partition to run the 5.1.41 software and subsequent updates?
Re: Fresh Start!
You can download 5.1.41 installation package from TerraMaster download center, and just install this version.
Return to “System Update”
