Change size of Volume.
Demos
Post by Demos »
f2-221, TOS 5.1.41. RAID 1
How to reduce Volume size? Common way (Control Panel – Volume, Choose Volume, push “Edit” button) doesn’t work. In “Edit” window when I try to print less capacity I have (See picture) and press “Confirm”, I see note “Operation succeed”, but nothing changes.
How to decrease Volume size?
TMeric
Re: Change size of Volume.
Post by TMeric »
The size of the volume can only be increased, not decreased. In the case that your storage pool still has space.
Demos
Post by Demos »
TMeric wrote: ↑16 Aug 2023, 23:25 The size of the volume can only be increased, not decreased. In the case that your storage pool still has space.
OK. If I need reduce the volume what should I do?
Sorry, you just can't.
ElPabloMaximo
Post by ElPabloMaximo »
In most storage scenerio's, volume shrinkage is not allowed because data is not always written from 'front-to-back' in a partition. Assuming you have the available space, you can
1) create a new volume of the desired size
2) move the data to the newly created volume
3) remove the old volume
This said, recent Windows OS can shrink a partition/volume but best to do a proper defrag first. Some storage systems 'say' they can shrink a volume/partition but they are really doing steps 1-3 I just posted in the background.
T12-450
TRAID Pool 1 - 2x2TB NVME
TRAID Pool 2 - 4x4TB HDD
TRAID Pool 3 - 4x6TB HDD
https://www.linkedin.com/in/paul-tippit-56496b17/
