I have a question about D2-310
terraking
Post by terraking »
hello.
I have a question about D2-310.
I plan to use RAID1 in 2 bays and install the OS on the hard disk.
If one of the two hard drives fails, like in a NAS or corporate server, is there a product that allows me to hot-swap the "failed hard disk with the OS installed" without stopping the PC and with the OS booted?
thank you
Re: I have a question about D2-310
Normally, RAID1 can support the replacement of old and new disks with the RAID synchronization function. This has nothing to do with hotplugging.
If a hard drive is damaged under normal working conditions, you can remove the bad one and add a new one to achieve RAID1 synchronization when the system is powered on.
Return to “USB Series”
