F4-423 Will not Shutdown via GUI
fcs001fcs
Post by fcs001fcs »
I just bought a new F4-423 the other day and I am continuing to set it up but have an issue when I want to shut it down via the GUI. It will not shut down and I must pull the power plug or hold the On/Off button for some seconds to get it to shut down. On one occasion it corrupted the drives and had to go through a long sync process.
It does Beep when I try and shut it down via the GUI but I waited 5 minutes, and it did not shutdown.
Pushing the Power Button once does the same this, a Beep but no shutdown.
Is there a fix for this problem?
F4-423 - 2 x12TB & 1x14TB & 1x16TB - BTRFS TRAID
Re: F4-423 Will not Shutdown via GUI
Please inform the applications and services you are using. Something may have affected the shutdown
fcs001fcs
Post by fcs001fcs »
Factory reset the NAS and started from the beginning and now it shuts down via GUI. So, working fine now, Thanks.
