Empty registry
Discussion about Docker
waymda
Australia
Empty registry
Post by waymda »
Hi
Docker newbie, but followed the instructions and installed and can't see or search anything on the Registry panel.
It has the default info of
Docker Hub
https://registry.hub.docker.com
TOS 5.1.
Is there something else I need to do?
A previous post mentioned it taking a long time to populate, but its been 3 days since installing.
Re: Empty registry
It may be a network problem, please make sure your TNAS can connect to the Internet.
You can try to modify the DNS, or log in to SSH, and use the relevant instructions of Dockerhub to directly pull the image.
viewtopic.php?f=78&t=2350
waymda
Australia
Re: Empty registry
Post by waymda »
Doesn't appear to be a newtwork issue, I get the same traceroute/tracert results form the NAS as I do my windows desktop, and I downloaded the Windows Docker manager and it accessed the registry immediately.
I won't be faffing around with software that doesn't work on install - I've got better things to do than trouble-shoot poor packaging/builds.
DERIKKU
Re: Empty registry
Post by DERIKKU »
Same here. :evil:
F5-221
TNAS 10TB
RAM 10GB
XFNeo
Re: Empty registry
Post by XFNeo »
{L_BUTTON_AT}waymda
What is docker app version?
баб28
Re: Empty registry
Post by баб28 »
I have two F2-221 and F2-223 devices and both show a blank screen in the registry. All the latest updates have been installed.
I don't know how to fix it.
There is Synology NAS nearby and it quietly loads containers from the hub.
waymda
Australia
Re: Empty registry
Post by waymda »
@XFNeo
1.2.2 the one the TNAS downloads and installs
If the suggestion is thats not up to date and I should hunt and download a different version Tmaster can go truck themselves - they really need to get their ship together if they can't keep their repositorys up to date and think selling a half baked solution is useful for their brand.
GalloTheFourth
Re: Empty registry
Post by GalloTheFourth »
I am also having the same issue, but it's not limited to the Docker Registry. It seems that DNS resolution is broken on this new version. Since it can't resolve the registry URL, it can't pull the images. None of my containers can resolve internet addresses.
баб28
Re: Empty registry
Post by баб28 »
Are the developers going to solve this problem at all? Well, at least some deadlines or let me know what the decision is doing.
Re: Empty registry
The issue has been verified, we will release a new update to fix it.
Return to “Docker”
