Hi All,
I purchased an F2-210 and have it working just fine but I've now tried moved it to my full network it tells me the IP has changed and to enter the admin password to change it.
That's the problem, there's no admin password.
I've looked at various set-up guides on YouTube and they all show it ask the user to set-up an admin password on fist start up.
Mine doesn't do that, it's never asked me to set on up.
I've tried 'admin' as a password to see if that was default but nothing.
I've reset back to factory multiple times and still nothing.
What is the default password or how do I set it?
Admin password
- crisisacting
- Silver Member
Re: Admin password
{L_BUTTON_AT}almighty15
The default is admin for both username & password: https://www.terra-master.com/global/faq ... l/?id=4177- almighty15
Re: Admin password
As I said my original post, tried that and it didn't work.
Re: Admin password
If your IP starts with 169.254, you can check the DHCP function of the router or refer to this method: viewtopic.php?f=78&t=1916
After you have installed TOS, you need to enter the password of the user you set when you installed TOS when modifying the IP, if not, you can try admin or Admin123.
By the way, do you mean complete network replacement?
