Cloudsyc/rclone for generic s3 (ceph+radosgw)
fabry68
Post by fabry68 »
Hello.
I have two TerraMaster F5-221, and I want to sell to my customers to have automated backups on my big ceph+radosgw cluster (S3 compatible).
In the last TOS + Cloudsync there is not a "generic s3" choice in the web gui, needed to configure a custom endpoint, but I can be able to access my cluster configuring manually cloudsync (that is rclone):
[fabry@TNAS-FaBrY CloudSync]# bin/cloudsync lsd tests3:
-1 2023-06-08 22:20:36 -1 nas-test
-1 2023-05-04 16:34:38 -1 nextcloud
-1 2023-05-04 02:35:09 -1 stampa3d
-1 2023-05-26 23:38:25 -1 testbucket
-1 2023-06-19 18:33:03 -1 testencryption
If I sell this nas to my customers, I can't "hack" them, but I need that the "generic ceph s3" can be used from the GUI.
Can you update your app with the required choice ?
Thanks, Fabrizio
fabry68
Re: Cloudsyc/rclone for generic s3 (ceph+radosgw)
Post by fabry68 »
PS: If, using a working amazon s3 credential, I create an AmazonS3 connection, going to /Volume1/@apps/CloudSync/etc/ and editing cloudsync.conf, changing "provider" to "Ceph", adding "endpoint" to my radosgw address, and of course using my credentials, I can be able to use my own radosgw Ceph S3 cluster.
Your feedback and suggestions have been collected. We are trying to reproduce it, and then we will discuss how to achieve this requirement.
fabry68
Post by fabry68 »
Thank you.
Please, feel free to ask me what you need.
Regards, Fabrizio
fabry68
Post by fabry68 »
Hello, any update on this topic ?
Thanks, Fabrizio
Hello, there is currently no plan. We will try to mention and discuss your suggestion again.
Return to “CloudSync”
