F5-221 VPN Connection Issues
Stevd
Post by Stevd »
Has anyone been able to set up a vpn connection to NordVPN or any other VPN provider from a F5-221
I have tried setting up the connection by downloading the config file and also found the server certificates. When I try to connect it just fails.
I see there is another similar thread but no outcome.
Re: F5-221 VPN Connection Issues
Hi, please make sure you have selected a correct protocol and used correct credential provided by your VPN service provider.
Stevd
Post by Stevd »
Yep, I have done all of that.
The only protocol which should work is the OpenVPN protocol as this is the only protocol that NordVPN allows from the terramaster list, but I just can't seem to get ot to play.
Stevd
Post by Stevd »
Terramaster TOS seems to force you to put a CA certificate in, however on other VPN setup tutorials it seems this isn't necessary. Am I doing something wrong?
Yes, a CA certificate is needed.
Stevd
Post by Stevd »
Even with a CA certificate, it still doesn't work.
Please contact us at support(a)terra-master.com, a remote check will be arranged for you.
Return to “Network”
