[TOS4]Uninstalled Music/Photo Library beta, but they're still hogging resources?
Troubleshooting
Applicable Model
All TNAS models
Applicable version
Earlier versions of TOS4.2.x
Symptoms
I have installed the Beta version of the application Photo Library or Music Library, because the related processes such as tnasdbd, minidlna, music, etc. take up a lot of computing resources, and I uninstalled the application for some consideration. But after uninstalling, related processes still remain and continue to occupy computing resources.
Solution
1. Please login SSH:
viewtopic.php?f=78&t=2350
Enter the following command to cancel the self-start of some related processes:
rm /etc/init.d/MediaSearch
rm /etc/sc.d/MediaSearch
Then restart
2. If you find that step 1 does not solve the problem, or if you want to completely clean up residual files, you can choose to reinstall TOS:
viewtopic.php?f=76&t=423
Return to “Applications”
