F4-210 stopped being seen on the network or app
Biggeek42
Post by Biggeek42 »
Was working fine no error messages all lights green
Mapped drives not showing and device is not discoverable
Any Ideas?
Re: F4-210 stopped being seen on the network or app
It seems that the system is not running properly. We suggest you try restarting it. If the problem persists after restarting, there is a possibility that the system may suffer from unexplained damage. At this point, you can try reinstalling TOS to restore the system to normal:
viewtopic.php?f=76&t=423
It is not ruled out that there may be a hard drive error. If similar errors occur again in a short period of time, please check your hard drive.
Return to “Network”
