TOS 4.x and Python 3.10.5 installation issues
francescof
Post by francescof »
i need to understand if there is a solution to my problem. I need to install this app:
https://tmnascommunity.eu/download/homeassistant/
(HomeAssistant TOS4 2022.11.1.0 x86_64.tpk)
And Python 3.10.5 is required, but I cannot install it.
The store allows to install Python 3.8 only.
I tried to install Python 3.10.5 from this link:
https://tmnascommunity.eu/download/python310/
(Python310 TOS4 3.10.5.0 x86_64.tpk)
It reaches 50% and the message is this:
("Error! The file is incorrect and it can not be installed.")
I tried with TOS 4.2.40. No way.
Last week: updated to TOS 4.2.41 Nothing changed.
Last week: Restore to factory - Now TOS 4.2.43 Nothing changed.
I also tried to install Python 3.8.12 (in every OS version).
https://tmnascommunity.eu/download/python38/
(Python38_TOS4_3.8.12.1_x86_64.tpk)
Nothing changed.
Every time i set up the language to EN to avoid any app language incompatibility.
What i am doing wrong? Thanks.
My hardware:
F2-210:
TOS 4.2, 1 pool
RAID1: 3.5" 2x 4TB WD RED WD40EFAX-68JH4N1
F5-422:
TOS 6, 3 pools
TRAID: 2.5" SSD Samsung 870QVO 1TB (OS)
RAID1: 3.5" 2x 8TB WD RED WD80EFBX-68AZZN0
francescof
Re: TOS 4.x and Python 3.10.5 installation issues
Sorry. I forgot my hardware. F2-210.
Thanks.
My hardware:
F2-210:
TOS 4.2, 1 pool
F5-422:
TOS 6, 3 pools
The model you are using is an arm architecture device, and the application you are installing is developed for x86 architecture devices (as can be seen from the name of the installation package). Perhaps you can find a version of the arm architecture.
francescof
The package is clearly for both x86 and x64.
My ARM uses x64 instructions (ARM V8 64-bit).
If you read in my link:
[...] Applicable models: x.64 series [...]
Am i wrong?
My hardware:
F2-210:
TOS 4.2, 1 pool
F5-422:
TOS 6, 3 pools
francescof
francescof wrote: 02 Jul 2023, 22:20 The package is clearly for both x86 and x64.
Am i wrong?
How many bad information on the net... Anyway you have right.
I have an ARMV8 architecture, that is 64 bit instruction but is not compatible with other product.
Terramaster has produced a completely useless hardware. Old, not compatible with any app and with an ancient and shameful hardware.
I wish Terramaster's engineers the worst.
TOS4.x
x.64 - last version - 3.0.4.1042.0 // the .tpk filename will contain x86_64 as example ModBase1_V1.00.00_x86_64.tpk
armv8 - last version - 3.0.4.1042.0 // the .tpk filename will contain aarch64 as example ModBase1_V1.00.00_aarch64.tpk
x.64 product serie
F2-221
F2-422
F2-423
F4-221
F4-222
F4-421
F4-422
F4-423
F5-221
F5-422
F8-422
armv8 product series
F2-210
F4-210
My hardware:
F2-210:
TOS 4.2, 1 pool
F5-422:
TOS 6, 3 pools
{L_BUTTON_AT}francescof
As posted on the community page you referenced: (and every other app download page, I guess)
All apps here are not officially provided by TerraMaster, but developed by *** in spare time. All the apps you can download here are free. If you encounter problems while using the app, *** can provide you with advice and help as much as *** can. Since it takes *** a lot of time to maintain these apps and provide technical support, *** would appreciate if you make a donation to support *** work and continue to provide up to date versions.
[*** is the app provider, to avoid any confusion. Nothing to do with me.] So, you are complaining to TM about something provided by a community member for free. You need to sort out your priorities. Maybe send the communiy member a donation!
francescof wrote: 02 Jul 2023, 22:33
Am i wrong?
TOS4.x
x.64 product serie
F2-221
F2-422
F2-423
F4-221
F4-222
F4-421
F4-422
F4-423
F5-221
F5-422
F8-422
F2-210
F4-210
I think it will be useful for you to read about CPU architecture on the link below
https://www.google.com/amp/s/www.partit ... html%3famp
The fact that your NAS can run 64bit applications, doesn't mean it is called x64 but ARM64.
In short
X64, also called x86-64, refers to the 64-bit extended CPU ISA (Instruction Set Architecture) based on x86, which is backward compatible with 32-bit x86 architecture and older 16-bit x86 architecture. In addition to the above names, x64 also has other names like x86_64, AMD64, and Intel64.
Return to “Others”
