[ FireflyIII ] Personal finance manager
About: https://www.firefly-iii.org
Category:
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.37 or later versions
App download: https://tmnascommunity.eu/download/FireflyIII
Required packages:
apache24
MariaDB
PHP81_okm
TOS4: http(s)://yournasip:port/modules/FireflyIII/www
TOS5: click on Support & Help from app description inside the App Center
1. Create a database using phpMyAdmin (from MariaDB app)
2. Adapt FireflyIII .env config and fill in the info for the database access (created on step 1)
3. Run these commands in ssh terminal
cd /usr/local/FireflyIII/bin/FireflyIII
/usr/local/PHP81_okm/sys/bin/php artisan firefly-iii:upgrade-database
/usr/local/PHP81_okm/sys/bin/php artisan firefly-iii:correct-database
/usr/local/PHP81_okm/sys/bin/php artisan firefly-iii:report-integrity
/usr/local/PHP81_okm/sys/bin/php artisan passport:install
You can now access the FireflyIII Web interface and create the first user
brunix86
Italy
Re: [ FireflyIII ] Personal finance manager
Post by brunix86 »
Hi outkastm,
Just a note about the installation of the Firefly III database into MariaDB, regarding the "env" config file:
  • Hostname 127.0.0.1 instead of localhost
  • Port 3307 instead of 3306
Otherwise, a DB error happens when you launch the SSH commands.
Best Regards ;)
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.1278 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
Indeed, this is described at point 2 on the installation steps.
And here again the guide to create and use the database files created with MariaDB app.
https://tmnascommunity.eu/2022/11/30/ho ... phpmyadmin
Also on the MariaDB app post https://tmnascommunity.eu/download/mariadb, it is mentioned to always use 127.0.0.1 instead of localhost and port 3307
brunix86
Italy
Post by brunix86 »
{L_BUTTON_AT}outkastm
Thanks, I see the DB guide now and it's all clear. Regarding the "recurring transaction" (via cron jobs), I ran the following command from SSH:
/usr/local/PHP81_okm/sys/bin/php artisan firefly-iii:cron
It worked but after some days I see the following warning into Firefly III:
Warning! It looks like it has been more than 36 hours since the cron job to support recurring transactions has fired for the last time. Are you sure it has been set up correctly? Please check out the help-pages using the (?)-icon in the top right corner of the page.
How I can correctly enable the Firefly III cron jobs into TNAS? Is there a way to check which cron jobs are scheduled? Thanks!
My NAS Environment
  • TNAS F4-424
brunix86
Italy
Post by brunix86 »
Hi outkastm,
I found how to correctly enable the recurring transaction via crontabs into TOS 5.1.67 (x86-64 system).
  1. Open crontabs file using a text editor:
    vi /etc/crontabs/root
  2. Append the following line, in order to run crontab each day at 3AM:
    0 3 * * * /usr/local/PHP81_okm/sys/bin/php /usr/local/FireflyIII/bin/FireflyIII/artisan firefly-iii:cron
  3. Save and exit from the text editor
Now it works fine!
My NAS Environment
  • TNAS F4-424
Much easier to use Cron_okm app for cron jobs. Also because the defined jobs will remain after reboots or TOS updates
https://tmnascommunity.eu/download/cron_okm/
brunix86
Italy
Post by brunix86 »
[at=outkastm post_id=30289 time=1697054968 user_id=2797][/at]
Of course I will try with your suggestion!
My NAS Environment
  • TNAS F4-424
In TOS5.1.nnn you could always use the customizable Scheduled Tasks function that is already built in. Works fine for me.
brunix86
Italy
Post by brunix86 »
Hi, could you kindly add instruction to upgrade the 5.7.18 version to the last one (6.1.0) ? I see that now is used PHP 8.3 and maybe the database is automatically upgrated. Or, if you could, update the TOS5 TPK package? https://docs.firefly-iii.org/how-to/fir ... lf-managed https://github.com/firefly-iii/firefly- ... ses/latest https://gist.github.com/JC5/909385c5086 ... e047446d68 Thanks!
My NAS Environment
  • TNAS F4-424
i have to compile PHP 8.3, it will take a while
