Can't connect for the first time
Half811
Post by Half811 »
I bought F2-210. But I can't connect. The browser does not see the server.
The PC program sees it, but when you click on "login" it gives the site not found.
Can't connect via ssh to ip:9222. Putty writes "connection refused".
Half811
Re: Can't connect for the first time
Post by Half811 »
It was possible to connect with port 22. But what is the login and password? admin admin and root root don't work.
tommi2day
Germany
Post by tommi2day »
For ssh you have to provide the system user and password created at installation time. This user became ID=0 means acts as root user
Thomas
main: T9-450
Did you install any drive in our F2-210? if yes, please power off your device, remove them all, power on back, and try again.
Return to “Network”
