F5-221 turn on same time everyday. I already did all steps, reset TOS 5, reset the BIOS, remove battery, clear the cmos and still same behavior. In another post updating the bios o re installed fix the problem.
- codycollins
Re: F5-221 turn on same time everyday
I think that updating the BIOS or reinstalling it may help resolve the issue.
Are you turning it off manually or do you have a schedule set?
Frustrated Beta Tester!!!
