How I Fixed My Unresponsive F2-210 NAS and Enhanced Its Performance
TG12
Post by TG12 »
Following a positive critique on a technology website, I was led to purchase the F2-210 for use as a compact home NAS. However, my initial experiences with the device left me feeling as though the product was fundamentally flawed upon arrival.
My setup involved two WD RED Pro 1TB drives, which I arranged in a RAID1 configuration. Unfortunately, the NAS would consistently lose its network connection and fail to respond to any kind of input or interaction. I initially theorized that the RAID 1 initialization process was the culprit behind these issues. But, despite leaving the system undisturbed for a prolonged period of over 12 hours, I saw no improvements or changes.
Out of necessity, I chose to reboot the entire system, during which I discovered that significant alterations to the sysctl settings were necessary to remedy the situation. After applying these changes, the NAS's performance significantly improved and has maintained its stability ever since.
To assist others who may be experiencing similar issues, I've developed two key resources: a file containing all the necessary tweaks, and a script to apply these adjustments. Following a system reboot, you can remotely access your NAS via SSH. From there, you can manually modify these files using 'vi' or copy them directly into the /etc directory and execute the script. Remember to change the script's permissions with 'chmod u+x' and run it as the root user.
With these modifications in place, the system's performance has been exemplary. Network dropouts have been completely eliminated, and I've managed to transfer a total of over 500GB of data and stream numerous media files without encountering any problems.
I invite all users to examine and verify these sysctl adjustments. However, do note that in my solution, I've focused on enhancing system performance rather than prioritizing energy efficiency.
https://github.com/tg12/script-toolbox/ ... _sysctl.sh
https://github.com/tg12/script-toolbox/ ... aks.sysctl
Re: How I Fixed My Unresponsive F2-210 NAS and Enhanced Its Performance
Why do you keep re-posting this?
TG12
Post by TG12 »
I understand that you may be wondering why I continue to post this information. The reason is simply due to my desire to inform as many people as possible. It seems that these products have some fundamental issues that cause them to be, in a sense, broken right from the start. A significant number of complaints about this have been noted here.
The solution I am providing aims to rectify these issues. I believe it is important to share this to help users overcome the problems they may be experiencing with their products.
I don't have an Arm based device (which is what I believe the F2-210 device to be) but just to satisfy my curiosity, there seem to be over 170 settings adjustments in your tweeks file. Are you saying that all these settings are different from those in the vanilla OS?
TG12
Post by TG12 »
Most of them probably not all. The script shows what will be changed.
