F4-220 compatible TNAS
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
pcarvalho
Post by pcarvalho »
I have an F4-220 that has died, I've followed all the instructions available to try to recover it with no success.
Is there a TNAS that I can just plug my F4-220 disks and they will be recognized and used without expected data loss?
Re: F4-220 compatible TNAS
Yes, you can buy a new F4-223, then plug in your drives to boot without losing data and system configuration.
pcarvalho
Post by pcarvalho »
Thank you, is the F4-423 the only option?
Thanks again.
pcarvalho
Post by pcarvalho »
pcarvalho wrote: ↑12 Jun 2023, 17:10 Hi,
Sorry I meant the F4-223
I just recommended you a model with a similar spec. Of cause you have many choices, just pick the x.86 models. go and overview our website to pick a model you like.
Return to “Compatibility”
