TOS Login HTTPS
vichi95
TOS Login HTTPS
Post by vichi95 »
at now i log in into tos desktop in http, how can i set https?
Re: TOS Login HTTPS
Hi vichi95,
To login your TOS with HTTPS, you need to login with IP address and follow a https port, for example 192.168.0.10:5443. To check or change the port, go to TOS > Control panel > Network service > network > General settings.
vichi95
Re: TOS Login HTTPS
Post by vichi95 »
I've tried to log in with port 5443 (default) but this error appean:
NET::ERR_CERT_COMMON_NAME_INVALID
Subject: *.tnas.link
Issuer: RapidSSL RSA CA 2018
Expires on: 16 ott 2021
Current date: 23 mag 2020
Re: TOS Login HTTPS
Did you remotely login?
vichi95
Re: TOS Login HTTPS
Post by vichi95 »
I've tried with local address and with .ddns service, i've also regenerate ssl certificate
Re: TOS Login HTTPS
TOS login HTTPS with your ddns service, input https://ddns_domain_name:5443, and upload ssl certificate of your ddns domain. By the way, you need to map port 5443 in your router settings too.
vichi95
Re: TOS Login HTTPS
Post by vichi95 »
Where can i upload the No-ip's certificate?
Re: TOS Login HTTPS
What's your current TOS version? Only TOS4.2.04 or later versions support uploading certificate.
vichi95
Re: TOS Login HTTPS
Post by vichi95 »
Actually 4.1.30. So, when a stable version of TOS 4.2.X will be release?
sports_wook
Re: TOS Login HTTPS
Post by sports_wook »
TMroy wrote: ↑24 May 2020, 12:16 TOS login HTTPS with your ddns service, input https://ddns_domain_name:5443, and upload ssl certificate of your ddns domain. By the way, you need to map port 5443 in your router settings too.
I've tried following these instructions on my F2-220 running 4.2.05 and the certificate will not upload. The "Apply"button has no effect after the certificate/key are uploaded.
