F2-221, notification "usb device has been removed incorrectly"
Terrauser07
Post by Terrauser07 »
Hi! Notification just constantly appears withous any usb drives plugged in.
Created network disk works incorrectly - All files shared for different users are closing spontaneously.
Re-installing TOS didn't help.
Hope it can be solved without replacement
Re: F2-221, notification "usb device has been removed incorrectly"
It may be that the USB installed with USB InitBoot on the motherboard is loose, You can try dismantling the device and re-plug the USB, if it still fails, you can unplug the USB, you can plug the external USB port of the device when installing the system in the future.
Regarding the problem of the network disk, we can only make some guesses based on the situation you provided. This may help you troubleshoot the problem:
viewtopic.php?f=77&t=2759
