unable to create rsync Backup task
Rsync is a backup tool common to most Linux servers and clients.
tommi2day
Germany
Post by tommi2day »
I try to create a rsync backup task to a synology, but the test is always failing. It shows a short red notice similar "operation failed, check server.."
I checked credentials several times.
Only Task to itself are accepted
On a commandline the rsync job works as expected
rsync -zvrae "ssh -p 22" /Volume2/progs [email protected]::NetBackup/
it looks similar to the unsolved task in viewtopic.php?t=3870
Any suggestions?
Thomas
main: T9-450
tommi2day
Germany
Re: unable to create rsync Backup task
Post by tommi2day »
No answers, even from Terramaster Staff? No way to use it properly?
main: T9-450
You can put the command in a cronjob and schedule it to run whenever you want
tommi2day
Germany
Post by tommi2day »
Yes, a cron or scheduled task will be the alternative. But I was hoping, at least this kind of basic software in TOS should work well, not talking about my other issues.
main: T9-450
We are going to release a new version, this issue will be fixed.
Return to “Rsync”
