F5-221 and USB 2.5G LAN Adaptor
SteveEtho
Post by SteveEtho »
I'm in the process of upgrading my network to 2.5GbE so thought I'd pick up the Terramaster A-USBLAN-2.5G for my F5-221, however after pluging the device in it doesn't seem to be detected in TOS 5.1.37. I was assuming a new interface would show up along the lines of "USB 1" or such but I still only see Lan 1 & Lan 2 under Interfaces. I hooked the adaptor up to my Windows 11 PC just to test it was working OK and it was recognized as a 2.5GbE network adaptor and worked fine. Also tried reinstalling TOS as a long shot but still no joy.
Any suggestions as to why the NAS can’t see it?
crisisacting
Re: F5-221 and USB 2.5G LAN Adaptor
Post by crisisacting »
Check through SSH to see if it's even detected using the following command:
lsusb --verbose
Also, check your built-in Ethernet ports, as some people have mentioned having an upgraded 2.5 Gbps adapter already present, out of box; use this command during the same SSH session:
lspci | grep Ethernet
SteveEtho
Post by SteveEtho »
Looks like it is being detected as I see this in the output:
SteveEtho
Post by SteveEtho »
Didn't notice there was another thread in this board with the exact same problem. Looks like it doesn't work with TOS 5 only TOS 4. Bit annoying since I'm not going to be downgrading too use it. Does any one from TerraMaster know if this will be resolved?
SteveEtho
Post by SteveEtho »
After a lot of testing various version of TOS and many, many factory resets the latest version of TOS I can run that will still successfully show the Terramaster USB 2.5GbE adaptor in the network interfaces is 5.0.176 any attempt to update past this point to a TOS 5.1 version causes the device to disappear from the Network interfaces window in TOS desktop.
At least there is a way to get a Version of TOS 5 running, hopefully at some point it can be made to work with a TOS 5.1 version.
Your persistence in verifying the problem is admirable. We will verify the issue.
SteveEtho
Post by SteveEtho »
Thanks for looking into this.
