D4-300 SAS Support
Chellarina
D4-300 SAS Support
Post by Chellarina »
Hi, I bought hard drives for my D4-300 but they're SAS, not SATA?
1.Does the device's controller support SAS?
If yes:
2.Can I somehow use a draw that supports the SAS drive?
If no:
3.Do I need a SAS to SATA adapter?
Finally, if the device dies not support SAS, do you have products that do?
Re: D4-300 SAS Support
D4-300 only supports SATA. We currently do not have any device model that supports SAS disk. We are not sure if you can make it work through an adapter. We recommend that you choose hard drives according to the compatibility list:compatibility
Return to “USB Series”
