VPN functionality
An application set your TNAS as a VPN server
sybarix
VPN functionality
Post by sybarix »
I've setup an OpenVPN server using my TNAS, and successfully managed to connect to it via the OpenVPN app on my Macbook by exporting the ovpn profile. I noticed several things do not work as expected:
1) My IP address does not change before and after connecting to the TNAS VPN.
2) I have enabled the option to "Allow clients to access the local area network where the server is located" as I thought it would enable my to connect to my apps via 192.168.xx.xx:xxxx from another network, but it doesn't work. Please let me know how to set this up.
XFNeo
Re: VPN functionality
Post by XFNeo »
{L_BUTTON_AT}sybarix
Hi! Have you tried a new version 2.0.49?
In release notes is mentioned that they fixed this option.
You can try changing to a different server specific static IP. If it works, you can try modifying it back to see if this is the main cause of the problem.
XFNeo
Post by XFNeo »
{L_BUTTON_AT}TMzethar
Hi! I have enabled "Allow clients to access the local area network where the server is located" on the latest version 2.0.49 and I cant connect to TOS UI via local address https://192.168.1.10:5443 but it works via https://172.10.11.1:5443
XFNeo
Post by XFNeo »
XFNeo wrote: ↑16 Aug 2023, 05:30 Hi! I have enabled "Allow clients to access the local area network where the server is located" on the latest version 2.0.49 and I cant connect to TOS UI via local address https://192.168.1.10:5443 but it works via https://172.10.11.1:5443
The problem is still relevant.
XFNeo
Post by XFNeo »
This is common. When you use the LAN IP of the VPN server to access the server itself, there may be routing conflicts.
Nitrokalel
Mexico
Post by Nitrokalel »
buena tarde en tos 7 cuando me conecto con openvpn no aparece mi conexion, es decir no aparece la conexion establecida en openvpn
F8 SSD Plus (8x4TB NVMe, TRaid, 48GB, prod)
F8 SSD Plus (6x1TB+2x2TB, TRaid, 48GB, prod)
F4-424 Pro (2x22TB+2x10TB HDD +1TB+500GB NVMe, TRaid, 32GB, prod)
F2-423 (2x18TB, TRaid, 32GB, prod)
F2-221 (6TB+10TB, TRaid, 10GB, prod)
D1 SSD (2TB, prod)
Nitrokalel wrote: ↑22 Apr 2026, 05:58 buena tarde en tos 7 cuando me conecto con openvpn no aparece mi conexion, es decir no aparece la conexion establecida en openvpn
What is the system version of these devices? TOS 6 or TOS 7? Regarding the issue you mentioned where the connection isn't showing, could you provide a screenshot to explain in detail?
Nitrokalel
Mexico
CursaYang wrote: ↑22 Apr 2026, 21:46
es en tos 7 no muestra quien esta conectado cuando la coneccion esta establecida
D1 SSD (2TB, prod)
Return to “VPN Server”
