About: https://github.com/axboe/fio
Applicable TOS4: 4.1.27 or later versions - on request
Applicable TOS5: 5.1.33 or later versions
App download: https://tmnascommunity.eu/download/fio
TOS4: http(s)://yournasip:port/modules/fio/www
TOS5: click on Support & Help from app description inside the App Center
Running fio is normally the easiest part - you just give it the job file (or job files) as parameters:
$ fio [options] [jobfile] ...If the job file contains only one job, you may as well just give the parameters on the command line. The command line parameters are identical to the job parameters, with a few extra that control global parameters. For example, for the job file parameter :option:`iodepth=2 <iodepth>`, the mirror command line option would be :option:`--iodepth 2 <iodepth>` or :option:`--iodepth=2 <iodepth>`. You can also use the command line for giving more than one job entry. For each :option:`--name <name>` option that fio sees, it will start a new job with that name. Command line entries following a :option:`--name <name>` entry will apply to that job, until there are no more entries or a new :option:`--name <name>` entry is seen. This is similar to the job file options, where each option applies to the current job until a new [] job entry is seen.
