Another Media server oddity!
Tricky
Post by Tricky »
Another thing that's been bugging me since the 29/31 update, I get this (when it works) on one of my smart TVs and the other says no content.
Re: Another Media server oddity!
Weird situation, what version of TOS and DLNA server app are you using? Does this issue also occur on other devices?
Tricky
Post by Tricky »
TOS 34 and current media server apps, one TV sees hundreds of either empty folders or recycle along with duplicates of films and music, the other TV just doesn't see any content, tried a reset on both TVs but makes no difference.
Is your media index successfully rebuilt after update?
Tricky
Post by Tricky »
Yes! Rebuilt and rebuilt again, seems to have no effect on this phenomena.
Tricky wrote: 31 May 2023, 15:56 Yes! Rebuilt and rebuilt again, seems to have no effect on this phenomena.
How is this issue going? it still persist?
Tricky
Post by Tricky »
Yes to a degree, I have now restarted with a fresh installation of 41 and using TRAID and all works OK but still getting duplicates of five for each movie or album strange!
Return to “System Update”
