adding drive
adding drive
I have a F2-223. I set it up with one 8TB drive using TRAID. I added a second drive, it says it was configured correctly. Is there any way to know the status of the synchronization process? It has been over 8 hours. There is no indication that it's running, or how long it will take.
exclusive dating with real women - https://privateladyescorts.com - erotic dating made simple
Re: adding drive
{L_BUTTON_AT}mfinn999
Please refer to this link:viewtopic.php?f=79&t=1542 。
After completing the above operations, you can see the progress of data synchronization in Control Panel>Storage Pool.To contact our team, please send email to following addresses, remember to replace (at) with @
Re: adding drive
I can complete the process of adding the drive to the storage pool, it asks me to select the drive, when I confirm, it says "configuring...", then configuration saved, but the settings never change. It still only shows HDD 1 in the storage pool. I can create and delete a new storage pool on HDD 2, but I'd prefer to combine them into one drive.
Re: adding drive
what is your second drive capacity?
Re: adding drive
Ahh, thank you for the pointer, for some reason I did not notice this until now.
They are both 8TBG drives, but the drive in the storage pool is 7.27TB and the drive I'm trying to add is 7.20TB. Does this mean I need to move the data to the smaller drive and then add the larger drive?
Re: adding drive
The drive capacity your newly added to RAID can not less than the smallest capacity in the RAID.
Re: adding drive
I swapped the drives, so now the storage pool is on the 7.20TB drive, and I am trying to add a 7.27TB drive to it. The storage pool is configured with TRAID. When I add the drive, it can see it, I can configure and confirm and I see a message that says "Configuring..." and then it goes back to the storage pool view but it still only shows the 7.20TB drive. I see no extra HDD activity. I have tried restarting multiple times, but it does not allow me to add the drive. Is there a log for this?
