Applicable models
T9-450, T12-450
Preparation
Windows PC, serial cable adapter (RJ45 to USB), Putty software
Steps
1. Turn off the T9-450/T12-450 and keep the power connected;
2. Right click and open Win > Device Manager > Ports (COM & LPT);
3. Connect the T9-450/T12-450 to the Windows PC with a serial port adapter, click "Scan for hardware changes" on the Ports (COM & LPT) page, and you will find a new "COM "interface;
4. If you do not find the new serial number of the "COM" interface, please contact the manufacturer of the serial port adapter to obtain the driver of the serial port adapter and install it to your Windows PC;
5. Assume that the new interface found is "COM7". Open Putty, select Session > Serial, enter "COM7" and baud rate "115200";
6. Select Terminal > Keyboard, check "VT100+", and keep other settings unchanged by default.
7. Click "Open" to open the display page, and then start the T9-450/T12-450, you can observe the BIOS interface on the display page and operate the BIOS through the keyboard.
