[i] Creating user: npm with password
2023-05-22 10:30:57 0 [Note] /usr/bin/mysqld (mysqld 10.4.15-MariaDB) starting as process 50 ...
2023-05-22 10:30:57 0 [ERROR] mysqld: File '/var/lib/mysql/aria_log_control' not found (Errcode: 13 "Permission denied")
2023-05-22 10:30:57 0 [ERROR] mysqld: Got error 'Can't open file' when trying to use aria control file '/var/lib/mysql/aria_log_control'
2023-05-22 10:30:57 0 [ERROR] Plugin 'Aria' init function returned error.
2023-05-22 10:30:57 0 [ERROR] Plugin 'Aria' registration as a STORAGE ENGINE failed.
2023-05-22 10:30:57 0 [Note] Plugin 'InnoDB' is disabled.
2023-05-22 10:30:57 0 [Note] Plugin 'FEEDBACK' is disabled.
2023-05-22 10:30:57 0 [ERROR] Failed to initialize plugins.
2023-05-22 10:30:57 0 [ERROR] Aborting
/scripts/run.sh: ignoring or entrypoint initdb empty /docker-entrypoint-initdb.d/*
MySQL init process done. Ready for start up.
exec /usr/bin/mysqld --user=mysql --console --skip-name-resolve --skip-networking=0
2023-05-22 10:30:57 0 [Note] /usr/bin/mysqld (mysqld 10.4.15-MariaDB) starting as process 1 ...
2023-05-22 10:30:57 0 [ERROR] Could not open mysql.plugin table. Some plugins may be not loaded
2023-05-22 10:30:57 0 [ERROR] AbortingMy Nextcloud compose file is:
version: "3.9"
volumes:
data:
db:
networks:
npm_default:
# add this if the network is already existing!
external: true
default:
services:
app:
image: nextcloud:latest
container_name: nextcloud-app
network_mode: bridge
restart: unless-stopped
volumes:
- data:/var/www/html
- type: bind
source: /Volume1/Disk1
target: /Disk1
environment:
- MYSQL_PASSWORD=
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
- MYSQL_HOST=nextcloud-db
- PHP_MEMORY_LIMIT=1536M
- PHP_UPLOAD_LIMIT=1536000M
networks:
- npm_default
- default
depends_on:
- "db"
db:
image: mariadb:latest
container_name: nextcloud-db
restart: always
command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW
volumes:
- db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=
- MYSQL_PASSWORD=
networks:
- defaultCode: Select all
version: "3.9"
volumes:
data:
ssl:
db:
services:
app:
image: 'jc21/nginx-proxy-manager:latest'
ports:
# These ports are in format <host-port>:<container-port>
- '80:80' # Public HTTP Port
- '443:443' # Public HTTPS Port
- '81:81' # Admin Web Port
environment:
DB_MYSQL_HOST: "db"
DB_MYSQL_PORT: 3306
DB_MYSQL_USER: "npm"
DB_MYSQL_PASSWORD:
DB_MYSQL_NAME: "npm"
# Uncomment this if IPv6 is not enabled on your host
DISABLE_IPV6: 'true'
volumes:
- data:/data
- ssl:/etc/letsencrypt
depends_on:
- db
db:
image: 'jc21/mariadb-aria:latest'
restart: always
environment:
MYSQL_ROOT_PASSWORD:
MYSQL_DATABASE: 'npm'
MYSQL_USER: 'npm'
MYSQL_PASSWORD:
volumes:
- db:/var/lib/mysql
