TOS 5 - Should I run my USB Backup HDD on BTRFS?
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
Toxster
Germany
Post by Toxster »
I finally managed to successfully shift my F5-221 to TOS 5.1 (had to delete storage pool, doing formatting and several re-installs because of strange storage issues).
I'm using a USB-connected 14 TB WD Elements HDD for my backups and I'm currently thinking about whether it would make sense to switch from NTFS to BTRFS on my USB-HDD. I think basic advantages would possibly be like protection of data corruption and also Snapshots could be used. Is this possible and supported by TOS 5?
crisisacting
Re: TOS 5 - Should I run my USB Backup HDD on BTRFS?
Post by crisisacting »
According to their FAQ, that file system is not supported via USB: https://www.terra-master.com/global/faq ... l/?id=4412
Toxster
Germany
Post by Toxster »
crisisacting wrote: 11 May 2023, 23:20 According to their FAQ, that file system is not supported via USB: https://www.terra-master.com/global/faq ... l/?id=4412
Thank you! Maybe then use EXT4 instead of NTFS?
Return to “USB Copy”
