About: https://github.com/mylar3/mylar3
Category:
Applicable TOS4: on request
Applicable TOS5: 5.1.33 or later versions
App download: https://tmnascommunity.eu/download/Mylar3
TOS4: http(s)://yournasip:port/modules/Mylar3/www
TOS5: click on Support & Help from app description inside the App Center
About:
Mylar is an automated Comic Book (cbr/cbz) downloader program for use with NZB and torrents.
Mylar allows you to create a watchlist of series that it monitors for various things (new issues, updated information, etc). It will grab, sort, and rename downloaded issues. It will also allow you to monitor weekly pull-lists for items belonging to said watchlisted series to download, as well as being able to monitor and maintain story-arcs.
Features:
Support for SABnzbd, NZBGet and various torrent clients (as well as Blackhole)
Multiple newznabs support, as well including a raw indexer and direct download being available
Ability to see upcoming new releases for a particular week and take action on them if required
View pullists up to 4 weeks in advance, or several months prior
TPB's and GN's are both supported as far as monitoring and post-processing (not import atm)
Can scan your existing library and download any missing issues
Failed download handling will download a new issue if one fails
Configurable file and folder renaming
Metatagging of issues via modified version of the awesome ComicTagger
Will automatically meta-tag downloaded issues either during (post-processing) or after (manual post-processing)
Generation of series.json files which contain series information for 3rd party applications
Notification on snatches / downloads using various notif applications
Ability to track story arc issues belonging to specific arcs, as well as various options pertaining to the arc
... AND SO MUCH MORE!
