Disable alarm beep from console
jbeazell
Post by jbeazell »
My F5-221 is currently recovering the RAID, and it is beeping beeping beeping beeping beeping beeping beeping. I do not have access to the web interface. That is sitting at a prompt to initialize the system, which I am not doing until the recovery is completed.
I need to stop the beeping. It is making me crazy.
Re: Disable alarm beep from console
when you get beeps, that means one of your drive loosing connection from your TNAS. You need to login TOS, mute the beeps and check what happened to your drive.
jbeazell
Post by jbeazell »
yah....
This I know.
Please read my post.
