Recommended USB Storage Devices for F4-423
topgazza
Post by topgazza »
I am having some issues backing up from TNAS to USB. I don't have the same problems using Carbon Copy Cloner on my Mac to copy the TNAS Plex folder to a USB device attached to the Mac. That works well.
But before I suspect the admittedly 4 year old 8TB WD My Book which until being used on the Terramaster was flawless I'd like to consider updating the drive. Anyone any thoughts for a 10TB External USB drive such as Seagate or WD Elements that they currently use ? Also what software do you use for TNAS to USB ?
Thank you
Re: Recommended USB Storage Devices for F4-423
Hi, may I know what is the exact issue?
