Backup Stops at 95%
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
topgazza
Backup Stops at 95%
Post by topgazza »
Plenty of space on my USB drive
The incremental back just stops around the 95% mark backing up 5TB to a 8TB disk. No reason given it just sits there doing nothing. Unfortunately it happens in the early hours of the morning but in any case there is no error or indication of why it stopped.
To be fair I tried it with TFM as well with a similar result which is bizarre. But I need to start somewhere so it anyone has any idea I would appreciate it
Re: Backup Stops at 95%
Did you back up from a USB device to TNAS or from TNAS to a USB device?
Please collect a system log report on the TOS desktop-decision technical support-issues feedback, and then send it to our technical support mailbox, we will do some preliminary analysis.(Please make sure that TNAS has not been shut down after the problem occurs.)
topgazza
Post by topgazza »
Thanks, I’ll do that
Trying again with TFM just to see
topgazza
Post by topgazza »
Oh, it was TNAS to USB
Return to “USB Copy”
