VirtualBox VM's gone after 5.1.24-00324 update
MooieBoot
Post by MooieBoot »
After the firmware update to 5.1.24-00324, my VM list in VirtualBox is empty. The vdi and sparse files are not lost (still on the Volume), but when I try to add the existing VM I get the following error:
VirtualBox error: rc=0x80004005 Extra content at the end of the document. Location: '/home/xxxx/xxxx/xxxx.vdi', line 1 (0), column 2. /home/vbox/vbox-6.1.18/src/VBox/Main/src-server/MachineImpl.cpp[499] (nsresult Machine::initFromSettings(VirtualBox*, const com::Utf8Str&, const com::Guid*)) (0x80004005)
Was vbox updated in 5.1.24-00324 update? Can't find any info on this, however I would like to have my VM's up and running and/or can I revert the firmware update?
Re: VirtualBox VM's gone after 5.1.24-00324 update
What systems do you have installed in VirtualBox? We haven't updated VirtualBox.
MooieBoot
Post by MooieBoot »
I had 1 windows VM and 2 linux vm's, but that doesn't really matter.
Somehow the "Default machine folder" within phpvirtualbox was changed and it wasn't by me.
Looks a bit like an earlier bug: viewtopic.php?f=73&t=2041
MooieBoot
Post by MooieBoot »
I think the update did something to my homefolder settings and is pointing to another location (/Volume1/User/xxx) instead of /home/xxx
mmick
Portugal
Post by mmick »
TMRyan wrote: ↑30 Apr 2023, 20:22 What systems do you have installed in VirtualBox? We haven't updated VirtualBox.
Sadly, why don't terramaster update virtualbox, even if it`s every 12 Months. On my fully updated F4-423, the VB version (VirtualBox 6.1.18) was released on January 19 ...... 2021 (!). I bought from Terramaster to use W10 VMs and it doesn´t work (error due to newer CPU and Virtualbox is too old and returns errors.)
rebelo92
Post by rebelo92 »
continue waiting for update to Virtualbox.......
Return to “Virtual Machines”
