U4-111 TOS 5.1.33 No Resources
Binary100100
Post by Binary100100 »
As the subject suggests.
I have an U4-111 model with 4 10TB in Raid-6 with TOS 5.1.33.
Absolutely nothing shows up in Resource Monitor.
It had worked using TOS 4.x but as soon as I upgraded to TOS 5 (after a system reset of course) I immediately noticed that it somehow still saved my resource monitor history from 4.x but would no longer run on 5.0.
I tried deleting the history hoping that it would somehow refresh but that didn't help.
Advice?
Also, when rebooting this system takes a very long time to initialize. It wasn't too bad with TOS 4... maybe 5 minutes. But with 5.1 it takes at least an hour! I receive a ping reesponse almost immediately and within about 5 minutes get access to my shared media but the OS takes forever.
Re: U4-111 TOS 5.1.33 No Resources
May I know how did you update your 4.x to TOS 5.1.33? may I know your update routine?
Binary100100
TMroy wrote: ↑30 Apr 2023, 14:25 May I know how did you update your 4.x to TOS 5.1.33? may I know your update routine?
I followed the instructions here:
https://www.youtube.com/watch?v=e1ukLBKdLaE
Basically I:
We're going to verify that.If this defect is found, we will Readapt this model.
Binary100100
TMRyan wrote: ↑30 Apr 2023, 20:17 We're going to verify that.If this defect is found, we will Readapt this model.
Thanks for looking into it. I've set this to alert my email and I'll stay tuned.
We did not find this issuse, you can reinstall TOS 5.1.33.
Binary100100
I just re-installed TOS_X642.0_Update_5.1.33_00360_2304141548
No resources.
Nothing is showing up in resource monitor.
I have it set to Enable continuous system resource monitoring with a retention of 30 days.
But everything says 0%. (Load, CPU and Memory Usage.)
Binary100100
I don't have an options button or a reset to defaults available.
I have a Settings option. I select that and the only option it leaves me is "Enable Continuous Resource Monitoring" with a retention time and storage location (which is greyed out and can't be edited. /tmp/TOS_CONFIG/sysem.db )
{L_BUTTON_AT}Binary100100
After updating from TOS4 to TOS5, some webpage caches may affect the display, please try to clear the browser cache.Can you provide us with a screenshot of your latest description?
Binary100100
I already did on the first post.
Return to “System Resources”
