How to install Thunderbolt 3 driver for your Windows 10 computer?
FAQs and instructions only for Thunderbolt series raid storage
Instruction
Applicable models:
TerraMaster TD2 Thunderbolt 3/D2 Thunderbolt 3 (D2-330)
TerraMaster D4 Thunderbolt 3(D4-330)
TerraMaster D5 Thunderbolt 3(D5-330)
TerraMaster D8 Thunderbolt 3(D8-330)
If you are a Windows OS user, before you can use a Thunderbolt 3 device on your computer, you may need to intall the Thunderbolt 3 driver.
Guidelines for installing Thunderbolt 3 driver
1. Download from your computer manufacturer's official website
  • Find "Support and Service" from your computer manufacturer's official website;
  • Input your computer model number;
  • Find driver download section, and select "Thunderbolt driver" then click download;
  • If you fails to find the Thunderbolt driver, download the latest monther board driver and update it.
2. Download from Intel official website
  • Make sure your computer is equipped with Intel's thunderbolt 3 controller;
  • Follow the instruction provided on the page to complete the download and installation;
After the Thunderbolt 3 driver installed, a Thunderbolt control software also installed on your computer. Find and open the Thunderbolt control software, approve the connected Thunderbolt device;
