HyperCache RAID error
dhfh522
Post by dhfh522 »
The status of my Hyper-Cache shows a RAID error, but the device seems to be clean. How do I resolve this?
mdadm -D /dev/md1
/dev/md1:
Version : 1.2
Creation Time : Sun Mar 19 04:22:26 2023
Raid Level : raid1
Array Size : 1000072192 (953.74 GiB 1024.07 GB)
Used Dev Size : 1000072192 (953.74 GiB 1024.07 GB)
Raid Devices : 1
Total Devices : 1
Persistence : Superblock is persistent
Intent Bitmap : Internal
Update Time : Sun Apr 23 07:45:52 2023
State : clean
Active Devices : 1
Working Devices : 1
Failed Devices : 0
Spare Devices : 0
Name : gfnas2:UTOSFC-X86-S64 (local to host gfnas2)
UUID : c78e0239:253f2dd7:c9d87c4a:35ef965b
Events : 8
Number Major Minor RaidDevice State
0 259 1 0 active sync /dev/sdza1
Setup:
TOS 6.0.650
T9-423(16GB)
1 x Intel 1Tb 670P Hyper-Cache
9 x 3TB HGST Ultrastar 7K4000
8 - members in TRaid array, 1 - Hot Spare
1 Storage pool with 2 Volumes
Backup
D5-300C
4x14TB ST14000NM0018 in TRaid array
1 Storage pool with 1 volume
TMtina
Re: HyperCache RAID error
Post by TMtina »
Hello, it is recommended that you pull out the sdza disk and format it, then restart the machine, and then insert the sdza disk into the machine to recreate Hyper Cache.
dhfh522
Post by dhfh522 »
There's no way to reformat it in the NAS?
Setup:
TOS 6.0.650
T9-423(16GB)
Backup
D5-300C
TMtina
Post by TMtina »
Yes, we cannot reformat it in the NAS, it needs to be formatted on another device.
dhfh522
Post by dhfh522 »
Following your instructions allowed me to to create a new SSD Cache (Cache 2), but I can't get rid of the original instance (with the RAID error)
Setup:
TOS 6.0.650
T9-423(16GB)
Backup
D5-300C
If this situation occurs again next time, please take a screenshot of it and immediately collect a log report on TOS>Technical Support, and then send it to our technical support email for analysis
mflow
Post by mflow »
dhfh522 wrote: 27 Apr 2023, 04:02 Following your instructions allowed me to to create a new SSD Cache (Cache 2), but I can't get rid of the original instance (with the RAID error)
got the exact same issues, tried to delete the Hypercache and remount it to another mode (from read only to balanced).
after one restart, the nas volume is inaccessible
the second restart allows me to access the nas volume, but remounting the hypercache gives me raid error
the third restart fixes all the problem, now it's working as usual
tab3rware
Spain
Post by tab3rware »
mflow wrote: 17 May 2023, 23:42
My case:
- Nas F2-223, 2 HDD, 1 M2.NVME. RAID 0, and M2 as hypercache
- Reinstall TOS
- I did an disk upgrade and changed from RAID 0 to RAID 1, after sync, i added M2 as cache. I found a ERROR RAID error.
- Restart
- Everythings works ok...
I hope it could help someone...
