T9-450 10GB SFP+ driver is broken on 5.1.29
gio
Post by gio »
TOS 5.1.29
T9-450
The 10GB SFP+ ports are broken and do not transfer data at fast speeds. In fact getting 50 Kilobytes speeds when copying files to NAS if I transfer to the 10GB SFP+ IP address.
If I copy over the 2.5GB port I max out 2.5GB port but what is the point of owning a 10GB NAS when it doesn't work at 10GB?
Proof: https://imgur.com/a/XjS9r9t - I already sent [email protected] the diagnostic logs and .zip file about a day ago but did not even get an automatic reply that a support ticket was created :? ... so posting here for attention.
Re: T9-450 10GB SFP+ driver is broken on 5.1.29
Is 10000GBps displayed in TOS after connecting to a 10GBps port? Did you try to transfer a large file or change the cable?
Return to “Network”
